RTBill's avatar
RTBill
Yet another water pump issue.
2016 Bounder 33c.
Shurflo 4008-101-F65 water pump. Kantleak valve system.
Vehicle was winterized last fall by dealer, while trying to de-winterize for the season, the water won’t flow from the tank to the faucets. The Kantleak valve allowed the tank to fill and allows for a city connection to flow into the coach but when the pump is on, no water will flow into any of the coach faucets. It has the feel that the pump is just not pulling on the water in the tank at all. Kantleak valve in the “normal” position and no water or even air coming from the faucets.
1. water heater drain plug back in place and bypass valve in normal position.
2. fuse box readout says 10amp fuse is good / replaced it anyway
3. water pump strainer checked and clear.
4. all plumbing connections seem tight.
5. when running with city connection no leaks anywhere.
Leaving from Michigan to Florida in 3 weeks and hope it don’t have to go back
to the dealer as they take forever to fix anything. Thanks so much for any thoughts or advice anyone can offer
  • Does the pump run? Did you check the hose the you pump the antifreeze with?
Having RV issues? Connect with others who have been in your shoes.24,357 PostsLatest Activity: Feb 02, 2026
