time2roll wrote:
What does a Zamp connector look like?
Is it same as an SAE 12v connector?
Some panels here:
https://www.solarblvd.com/product-category/solar-panels-systems/12-volt-solar-panels/
Do you need a controller?
That's the connector, although the Zamp port installed by most if not all OEM's is typically reverse polarity, so You need to reverse the leads on either the connector your plugging in or the wiring installed by the manufacturer. You also usually need a controller in most cases, as the OEM port is typically just that and wired directly to the battery connection.
