cummins2014
Aug 07, 2023Explorer
Cummins12V98 wrote:
RAM having adjustable spots is a waste of money as I set mine once to the furthest out position and never adjusted again.
My big concern for the FORD is the HOT transmission temps. I never see over about 172 pulling in near 100 degrees on long 6% grades. Most of the time I run 165-167.
Shows how dumb it is to do a leveling kit on a tow vehicle.
No denying it it has a ton of power!
I don't doubt the Aisin will do that if you say so ,the 68RFE will not running those long grades. I will see nearly 200 with my 68RFE , solo it runs a pretty consistent 172 , towing in hot weather it's a consistent 185-190 .
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
