Cummins12V98
Aug 07, 2023Explorer III
cummins2014 wrote:Cummins12V98 wrote:
RAM having adjustable spots is a waste of money as I set mine once to the furthest out position and never adjusted again.
My big concern for the FORD is the HOT transmission temps. I never see over about 172 pulling in near 100 degrees on long 6% grades. Most of the time I run 165-167.
Shows how dumb it is to do a leveling kit on a tow vehicle.
No denying it it has a ton of power!
I don't doubt the Aisin will do that if you say so ,the 68RFE will not running those long grades. I will see nearly 200 with my 68RFE , solo it runs a pretty consistent 172 , towing in hot weather it's a consistent 185-190 .
My 68RFE in my HO DRW never saw 200 unless it was stop and go. For sure it did not run as cool as my AISIN does.
Maybe the Ford at those temps gets better mileage???
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
