Grit_dog
Aug 10, 2023Trailblazer
^100% correct. It’s the risk of while towing heavy (or otherwise), having it stick closed and heat the trans oil up to frying pan temperatures in very short order.
It’s pretty easy to discern if the temps are moderately higher than the thermostat set point as you and others have described, vs unexpected temp increase with no plausible reason.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 03, 2026
