4x4ord
Jul 26, 2023Explorer III
Cummins12V98 wrote:
It's just that he basically was bad mouthing something he should not have. "Bad transmission it needs more gears", it has gears he could have used them.
The standard output Cummins doesn't have the kind of torque rise that the high output does. More gears behind the Standard Output would help it perform a little better.
As presently tuned, the HO wouldn't benefit much at all by adding gears. If they ever put more gears behind the High Output Cummins they will probably flatten out the torque curve a little bit as well. By doing so they will increase the peak HP some to help it compete a little better with GM and Ford.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
