4x4ord
Jul 31, 2023Explorer III
^^^And if you're happy with 6 gears behind your 2015 Cummins you'd be ecstatic with 6 gears behind a new HO Cummins. Your 2015 is probably only making about 345 HP at 2200 rpm so someone could at least argue that a 2015 would benefit from more gears. The new HO engine will make more like 415 HP at 2200 rpm .... more gears certainly isn't going to make it pull a hill any faster. It might be nice to have another overdrive gear for running empty though.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
