Cummins12V98
Jul 31, 2023Explorer III
4x4ord wrote:
^^^And if you're happy with 6 gears behind your 2015 Cummins you'd be ecstatic with 6 gears behind a new HO Cummins. Your 2015 is probably only making about 345 HP at 2200 rpm so someone could at least argue that a 2015 would benefit from more gears. The new HO engine will make more like 415 HP at 2200 rpm .... more gears certainly isn't going to make it pull a hill any faster. It might be nice to have another overdrive gear for running empty though.
It's nice you understand all this, and you seem to be the only one!!! Like I said 3.42's would net me a touch better highway mileage. 3.42's are basically same rpm in 5th as my 4.10's in 6th, 1,750.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
