4x4ord
Aug 01, 2023Explorer III
^^^GM and Ford can hold back pretty good once the engine is revved up. The Cummins starts holding back at a much lower rpm but then doesn’t rev as high. Being able to hold back without dropping three gears is way nicer. So even if GM and Ford can provide the same reverse hp at 4000 rpm that the Cummins provides at 3000 rpm the clear winner is still the Cummins.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
