FishOnOne
Jul 31, 2023Nomad
4x4ord wrote:
The trouble with mpg tests is that they don’t take into account cleaning the DPF. To be accurate the test should start with a clean DPF and end the same way.
Your correct... I would say the best way to check fuel economy on a diesel is to run it from a clean DPF (after regen) until the completion of a second regen.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
