Cummins12V98
Aug 01, 2023Explorer III
FishOnOne wrote:Cummins12V98 wrote:FishOnOne wrote:Cummins12V98 wrote:FishOnOne wrote:Cummins12V98 wrote:
This BS of fill til it clicks and wait then same is a joke. It takes a bit but you can fill to the top if you want.
I think this method is legit as long as you do it the same way every time.
Haven't you noticed different flows if someone else is filling on your island while you are also?
So you mean to tell me that another pump on the same island pumping fuel at two different locations is why these two Duramax trucks yielded impressive fuel economy results?
WOW, put words into my mouth!!! I never said a word about the results just the method of fueling. Remember reading and comprehension go together. :B
I gave you an example with a question of why it can't be accurate but you chose not to address my statement/question.
But yet your trying to disqualify these fuel economy tests from two different sources. So based on the fueling error you're claiming how much did it affect the reported fuel economy results?
IMO the error is in the noise.
Lot's of noise. Bottom line, fill to the top each time and it is exact.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
