ktmrfs
Aug 16, 2023Explorer III
Grit dog wrote:Cummins12V98 wrote:
This BS of fill til it clicks and wait then same is a joke. It takes a bit but you can fill to the top if you want.
You literally have a truck that will make a mess if you try doing that, just like all other capless fuel fillers I’ve seen…. And what is the difference really? If it’s a similar flow rate pump it’s gonna foam and click off about the same (talking about diesels) yes the click off is more accurate with gas since it doesn’t foam up.
GM basically solved the "foam" problem long ago, At least by 2015 there is a wire mesh in the filler neck that drastically reduces foaming.
Don't know if ford and dodge have done the same, but wouldn't be suprised.
My 2004 foamed and I could get quite a bit more in the tank. 2015, not worth the effort, it gets it so close to full.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
