JRscooby wrote:
specta wrote:
JRscooby wrote:
In my mind the pedal rubbers are upside down.
Fixed. Thank you. :)
Better, but still not sure of the brake pedal. Most of the Fords I have owned/driven had clutch, brake that was same size as clutch, or a foot valve then the skinny one on right. If the brake pedal was shaped like that, no clutch pedal.
Here's my 1979 F-250 4wd. Same as my '76 with the wider brake pedal.
And my 1972 F-250 2wd auto trans.
You would think the auto trans would have the wider brake pedal than the 4-speed. I wonder when the change occurred????
I guess I could have gone back and looked at my own pictures to see if the pads were upside down or not. :)
