cummins2014 wrote:
It will definitely raise your heart rate , especially when you are on the brakes , and you start sliding sideways , so you let off , and then repeat , I came off a couple a bit faster then wanted . Or climbing and spin out , I got to when I’d lose momentum I’d let off throw it in reverse, and pop the clutch to catch me going backwards , that also raised the heart rate . Or spin out kill the engine , both feet on the brake , and sliding backwards, that was exciting .:)
Been there done that in my other truck. Never had an issue with the t-case. Sometimes you just end up in one of those situations and you do the best you can. :)
