RG7fan
Jul 10, 2008Explorer
cachingcampers wrote:
Realy dumb question.....I realize this is a "Dexter" made kit, I'd like to install it on my KZ which has Alco axles/springs. Is this kit "universal" or should I be looking at something else.
I did read the specs on Dexter's website, but it doesn't indicate if it fits any other manufacture's then Dexter.
TIA!
BTW, nice work Les!
I had the same question about this kit for my Starcraft TT with Lippert axles and springs, here is the response I got from Dexter.
The DEXTER AXLE E-Z Flex equalizers are designed to be direct replacements for specific size cast iron equalizers.
The P/N K71-654-00 equalizer kit is a direct replacement for equalizer p/n 013-104-02. These equalizers have the bottom hole spacing at approximately 5.7” If you have an equalizer that have hole spacing of 5.5” to 6.0 inches than you can use the K71-654-00 kit.
The p/n K71-655-00 equalizer kit is a direct replacement for equalizer p/n 013-122-02. These equalizers have the bottom hole spacing of approximately 7.67 inches. If your equalizers have hole spacing of 7.5 to 7.75 inches then the K71-655-00 kit will work.
Duane Belisle
Dexter Axle Product Engineer
574-296-7334
574-296-7320 Fax
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
