brohloff
Jul 10, 2008Explorer
Put the Dexter HD Suspension Kit in our '05 Nash TT this spring. Was not the E-Z Flex but a regular suspension. Went well. Took about 6 hrs. I used an 8" C-clamp to press the bushings in. Worked well. I positioned all the grease outlet holes in the down position (as it made the most sense to me that that is where the clearance will be when the weight is on the suspension) and had only a problem getting grease to one of the 14 greaseable bolts.
Also, I positioned all my zerks to the inside, rather than to the outside as Dexter shows, as it seemed easier to slide under the TT (lots of clearance under the Nash) rather than have to take the wheels off to grease them. At least IMHO.
A great TT addition for the $120 spent. Too bad Dexter doesn't add these as OEM.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
