JBarca
Mar 01, 2009Nomad II
Highway 4x4 wrote:
Did mine today, all went well except now my knees are dead. The spring hanger bolt did not seat up against the spring hanger even after torqueing down the nuts. I guess I will have to press them in.
Highway, good for you.
The bolts, yes press them home before torquing. The nuts can and do strip trying to take the force to seat the serrations of the pin inot the hanger. They are not that high of a grade of nut. Plus if you are not holding the head of the bolt you can strip out the metal in the hanger with the serations due to the higher torque trying to seat the bolt. It is amazing how much press is required to seat the bolts. Oh and driving the them home wiht a hammer, bounces around too much. A clamp of some sorts works well.
Good luck
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
