Learjet
Mar 12, 2009Explorer
LAdams wrote:
Nice job Learjet :B Boy, looks like you got to those shackles just in time, that one looked pretty thin toward the top...
Regarding the frame issue, I'm not seeing what you say needs repair - could you expound a little bit :Hbearing looked pretty sad for only 22K miles :( I'm gonna have to pull mine this year and see what they look like... I have less miles than you did but no doubt they are chinese bearings as well :M
Les
Ok, I edited the pictures.
Les, look at the bottom of the side support where its welded to the frame. You can see I cleaned some areas in some of the pics where the crack radiates out. Follow the rust line from the bottom out. This is a thin wall box frame, not I-beam. Those rust lines are cracks.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.251 PostsLatest Activity: Jul 10, 2026
