Community Alumni
Jun 05, 2009Not applicable
TankerDude wrote:
snip....
No problem with top of tire clearance. This TT is a tandem axle, and was built a little higher anyway. A 1.5 inch drop didn't bother it a bit....snip
I would confirm your actual tire clearance under loaded conditions. The Eagle is a heavy TT and had I put on the actual Dexter EZ-Flex Equalizer my tire clearance would have dropped from a standard 3" to 2". I have to had 2" to my center hanger bracket to maintain 3".
I agree with John, if you are running a 2" clearance or less, tire rub is very possible. I called Dexter Tech Support and they said that a 3" clearance is required with the axles supplied on my 2005 Jayco Eagle to insure that the tires won't hit the top of the fender well.
Turk2500
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
