RCMAN46
Sep 04, 2009Explorer
I just installed a wet bolt kit on my Equa-flex. For those that have had problems getting your bolts to take grease note this. Before installation I removed all of my grease zerts to make sure the bolt holes were free of foreign material. I found one bolt that was not completely drilled. It lacked about one inch of reaching the cross hole. That bolt obviously would not take grease. Easy to check installed systems. Remove the grease zerts and probe the holes with a small drill bit. If you find a shallow hole you have a problem bolt. This system came from Lippert which is known for lack of quality control.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
