RCMAN46
Oct 08, 2009Explorer
dcopps wrote:X2. When I installed a wet bolt kit on my Cruiser with the Equa-Flex one of the bolts that was supplied had not been completely drilled. It had a grease zert but could not accept any grease. X2 on the cost to rent the ball joint press.
Fill the bolts with grease before you install them and that will tell you if the port and fittings are working.
Good Luck
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
