JBarca
Oct 11, 2009Nomad II
Scuba Chop wrote:
I'm trying to install the wet bolts on my Jayco as part of a MorRyde SRE 400 system install. Did everyone that did this successfully fasten the spring ends in the end hangers first them work on the middle? I can't get the spring ends to line up in the hangers. Wondering if I'm doing it backwards by installing the middle first then trying to line up the ends.
I did the spring ends first, then the equalizer area as the shackels will pivot to where ever I need it to go verses yanking the axle and all.
I really never thought about starting from the middle but if you do you have to deal with the axle wanting to pull against you.
Good luck
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
