Steveque
Oct 13, 2009Explorer II
You may find the axle will move easier if you support the axle with a floor jack and then use a bottle jack under the front hanger of that spring. It does take a little coordination to lift and drop the jacks to make the spring move towards the rear.
I found that once I was close, I could just tug on the axle just a little to get the hole lined up.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
