JBarca
Dec 31, 2009Nomad II
RCMAN46 wrote:mudpuppi wrote:Believe me you will probably need the ball joint tool. When I did mine there is no way a c clamp would have done the job.
Thanks Amdriven! I have a large C clamp that I use on a lot of things but I think I will go ahead and get the ball joint tool just to save me some frustration. I'm sure that once I do my TT our friends will want to do theirs (they are already asking a lot of questions about it. The tool should pay for itself. I really like the fact that each bolt can be greased.
Yes you are correct that it does take a lot of umf to push the bushings in or worse the spring bolts. If your clamp has a 3/4" thread it can just get you buy. Mine did. However I have large clamps with 5/8 threads and they are not striong enough. So defining large, it needs to be 3/4 acme thread or larger which is what the ball joint tool adds. I think it is 1".
Mine worked, but it just made it. So "Be Prepared"
Hope this helps
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
