RetchedOne
May 18, 2010Explorer
TURK2500 wrote:BarneyS wrote:RetchedOne wrote:
How do I measure for what kit I need?
Jayco 19ft TT
They only make kits for two axle spacings - 33inch and 35inch...snip
Adding to Barney's comments, I found with my Jayco Eagle (your Jayco model may be different) that the existing equalizer was 2" taller than the Dexter equalizer (hole centers), so if I had installed the Dexter equalizer my tires would loose about 1" wheel well clearance. I did however install the wet bolts and HD shackles for now. The photo shows the difference in height of the respective equalizers, but once I get around to extending my equalizer hanger mount I will install the Dexter equalizer.![]()
Turk2500
I think i see what your saying, but if i dont catch this, and install the equalizer, will it be bad?
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
