BarneyS
May 18, 2010Nomad
RetchedOne wrote:
I think i see what your saying, but if i dont catch this, and install the equalizer, will it be bad?
It would mean that your tires could possibly rub on the top by touching the top inside surface of the wheel well if you hit a large bump or drove over a curb. I really doubt though that your trailer has the taller equalizers like Turk2500s does.
When you get the kit, compare the two equalizers like the picture posted by Turk2500 and see. Then you could run one wheel up on a ramp or lift one axle with a jack (put the jack under the spring hanger plate - NOT under the axle itself) and see how much clearance you have over the top of the tire. Compare that number with the difference in the two (if any) and that should tell you if they will work or not.
Barney
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
