cummins2014
Dec 15, 2010Explorer
Wow, what a thread, so many questions answered I too will do some upgrading on my suspension. Now instead of going in somewhat blind, I have all the info I need. I have the Mor-Ryde LRE suspension ,and I am going to add a wet bolt kit, but will buy my kit directly from Mor-Ryde, they upgrade the shear spring brackets so they can also be greased. If I went with dexter it would not address them. Also they will change some of the bolt lengths in the kit to accommodate a brace system that I am fabricating going from one side to the other , which is bolted to the hanger brackets, and also the middle suspension plate. Similar to Mor-Ryde's X-Factor. I noticed on one of the post that someone had welded what looks like pipe from one side to the other, that is probably the same function as what I am doing. What it is supposed to do is take out frame flex. Hopefully it will help. I have had no problems, but I plan on putting on more miles than I have done in the past. Thanks to all for all the great information
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
