Community Alumni
Feb 08, 2011Not applicable
dfm wrote:
snip...Has anyone with a jayco 322fks done this mod? How much lower was your trailer after the mod?
Be careful, depending on the size of the existing Jayco equalizer there is the possibility of clearance issues. I found on my 2005 Jayco Eagle 278FBS do to the height of the existing Jayco equalizer that installing the Dexter EZ-Flex Equalizer would lower my tire/fender well clearance. The only way around this would be to lengthen the equalizer shackles, which I decided to put off for another time. I did however install all the wet bolts, bushings, and new HD leaf spring shackles.
If my memory serves me correctly, there was a 2" difference between the hole centers between the two equalizers, which would reduce the clearance by 1". The following pic shows the EZ-Flex up against my Jayco OEM equalizer.
Turk2500
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
