Community Alumni
Feb 08, 2011Not applicable
Snowman9000 wrote:
It should not be any lower, or higher for that matter, as long as you order the proper kit.
Not true, there are more variations of OEM equalizers (some wider, some taller, etc.) than Dexter EZ-Flex kits.
Referencing my prior post, the tire/fender well clearance for my TT under load was 2 3/4 inches, had I installed the EZ-Flex equalizer I would have dropped to 1 3/4 inch clearance.....to tight IMO with my heavy TT.
I also found that Dexter Axle recommends that RV manufactures allow for a 3" tire/fender well clearance with their axles.
Turk2500
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
