JBarca
Feb 28, 2011Nomad II
chimarios wrote:
nice pic's does this suspension kit reduce sway and how much was it
thanx
Hi chimarios
In my case I noticed the most effect of the EZ flex the 1st day I towed with it. The bumps felt softer and inside the trailer things where less fussed while towing. After you tow with the EZ flex you sort of reset your memory of the feel of not having it and the "new normal" becomes the norm.
I myself have not noticed any difference in sway, more or less. In my case I'll call this mod neutral to ant sway effects.
This winter I have added TT shocks. If can then compare shocks in combination with the EZ flex. I have heard, (not yet experienced) that shocks can help create a more stable towing trailer from less left to right bounce. I'll let you know once the weather allows a weekend campout.
Shocks do different things then the EZ flex does for the suspension. Both do positive enhancements to TT towing.
Others may also give some comments on what they have felt.
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
