JBarca
Mar 12, 2011Nomad II
sndman7 wrote:
Well this has been a great thread with a lot of great info.
My question is does this help with axle alignment issues. I have been thinking of installing the Correct Track system because my axles are 1/2" out. I suppose I could install both.
Thanks
Hi Dennis
I have seen the correct Track system. Unique and it will give you course adjustment for a thrust angle that is out of alignment. It will not fix toe or camber.
Have you checked thrust angle, toe and camber? You may be fighting more then 1 thing.
This post of my axle correction may help. I made adjustable axle seats which is more fine an adjustment then the Correct Track. And I ended up getting new axle tubes as well to fix the messed up toe angle.
TT axle alignment & install - Detailed (long lot's of pics)
Good luck and hope this helps
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
