JBarca
Nov 23, 2012Nomad II
allen8106 wrote:
While I would like to add shocks But I'm a bit reluctant to being afraid I would void the coach warranty. It's a two year factory warranty that still has 4 months on it plus three more years extended warranty.
Understand your thinking. Maybe try to contact with Jayco direct at the factory. Ask if adding shocks will void your warranty and get it in some form of writing, even an email if they state it is OK.
If they state it will void your warranty, that does not set well for adding a suspension upgrade that should be on every trailer to begin with. I thought Jayco installs them on their high end 5'ers. This sort of falls in line with a WD hitch. How many people have ever asked a manufacturer if it is OK to add a WD hitch? Some even require they drill holes in the frame to mount a friction sway bar or a DC as well.
Jayco has been a good company. It would be a real eye opener if they denied the additions of shocks. If you do go through with the shocks, balance the tires as well. Another problem in the RV industry.
Good luck
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
