AH64ID
Apr 14, 2014Explorer
I wanted to say thanks for the stickey.
I did 1/2 of this install yesterday in about 2.5 hours, including installing some dynamic wheel balancers, inspecting wheel bearings, and removing tire weights.
It was a very easy install, the bushings pressed right in with a 4" "C" clamp after sitting in the freezer for a few hours.
I opted to remove the zerk from the wet bolts for installation and it made it much easier than trying to work around them.
I was expecting my ride height to be slightly lower, but it looks level with the drivers side still on the OE AL-KO setup.
Speaking of the AL-KO setup I have 7K miles on my TT and 2 of the bushings where nearly worn thru, so I am glad I did this.
I also will need to go a major wheel bearing service/upgrade before my next big trip. They looked fine, but the grease was worse than expected and the bearings look cheap.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
