brulaz
Nov 21, 2015Explorer
JBarca wrote:brulaz wrote:
Do you try to take the weight off the bearings when you grease?
Thanks for the help.
Do you need to take the weight off to grease? I'll say "It depends"
Sometime the grease holes in the spring pins gets mixed up which way they are suppose to be pointing in regards to the weight of the camper pressing down on the hole. If you put a grease gun on the zerk fitting and cannot pump it in, (meaning excessive high pressure and cannot squeeze the handle) Then in this case jacking up the camper will take the pressure off and let it go in. OR you have to pull apart the pins, rotate them and put them back in so the camper weight does not cover of the hole shut.
If the grease hole is in the right location, then they will take grease with the camper on the ground and it goes right in no problem.
I grease mine with the camper on the ground with no issues. The grease will find the path of least resistance and start to ozz out the side of the bushing that is not sealed the tightest.
Hope this helps
John
OK. I was thinking if you take the weight off the weight-bearing side of the bearing, there's better chance of getting grease on that side. But it sounds like it works it's way around the bearing anyway.
So as long as the bearings take grease, you are good. That makes it simpler. Thanks again.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
