JBarca
Nov 21, 2015Nomad II
brulaz wrote:
OK. I was thinking if you take the weight off the weight-bearing side of the bearing, there's better chance of getting grease on that side. But it sounds like it works it's way around the bearing anyway.
So as long as the bearings take grease, you are good. That makes it simpler. Thanks again.
Hi,
Just a clarification, you said bearings. We where talking about the bronze bushings in the spring eyes or the EZ flex. Are you using the word bearing for bushing? Granted both are bearing material as far as context of a word, but if you mean "wheel bearing" like in the tapered roller bearings in the brake drum, let's talk some more about the jacking up part.
I was referring the bronze bushing with the camper being on the ground.
Thanks
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
