JBarca
May 04, 2016Nomad II
brulaz wrote:
Lifted each side and all bolts took grease easily. If this were all I was doing, I wouldn't even have to put jack stands under it, as all grease nipples are easily accessible from the outside, and I don't have to crawl under.
Actually think lifting it up is the best way to do it. It removes pressure off all bushing surfaces as much as possible so grease will flow more freely, especially onto the weight bearing surfaces.
Yup, there is nothing wrong with the way you are doing it. It works. Thanks for reporting back
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
