brulaz
Jan 11, 2017Explorer
chilly81 wrote:brulaz wrote:
I do that to grease the bushings, they take the grease better with weight off.
I do it for tires and wheel bearings and such - but was just thinking once you disconnect one side of the suspension it might be another story. With weight on the other end of the axle does it make it really hard to maneuver back into place, etc.
Could be. I had a shop do it, and they put the whole trailer up on blocks, so all wheels were suspended at once.
You should be able to do that if you have enough supports. Lift one side, add supports, then the other.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
