Bobandshawn
Jan 24, 2017Explorer
minnow wrote:
The nuts that come with these kits are not serrated. Is anyone concerned that the replacements nuts will back off the threaded bolt ? Has anyone bought the serrated flange nuts aftermarket and used them instead ?
Not really. I got the Mor Ryde big bolt set up which requires longer bolts. I did put some blue loctite on them If you are really concerned you could get lock nuts for them. I don't see a need for cotter pins and castellated nuts in this application.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
