DesertTracker
Mar 28, 2017Explorer
So I am running into a problem. I ordered the Equa Flex equalizers and the Never Fail bushing kit, both from Lippert, and the parts do not fit together! The equalizers showed up with thin .040" plastic (Teflon?) bushings and the Never fail kit came with .060" bushings. The thin are too thin and the thick are too thick. The supplied 9/16" step bolts are sloppy in the thin bushings and will not push thru the thicker ones once installed in the equalizers. I called Lippert and they told me the top bushings should be brass, and sent me two. The brass will not even come close to pushing into the top hole of the equalizers. I gave up and took the trailer and parts to a local RV repair shop. After three days he called me up and said come get the trailer, the parts don't fit together. Lippert changed out the parts, and the new measurements are the same as the old. ???
I can't seem to figure out what bushings and bolts go into the equalizers and even worse, Lippert doesn't seem to know either. They look like nice equalizers, but they are not doing much good sitting on my bench in the garage. I am at a total loss on a solution for this one.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
