JBarca
Mar 29, 2017Nomad II
DesertTracker wrote:
I can't seem to figure out what bushings and bolts go into the equalizers and even worse, Lippert doesn't seem to know either. They look like nice equalizers, but they are not doing much good sitting on my bench in the garage. I am at a total loss on a solution for this one.
Hi,
I don't know if this will help, but here goes. You did not state which Equ-Flex you bought. In my last post a few responses up, I suggested to use the larger EQ unit on your trailer and there was a qty of reasoning behind that.
On mine, the larger unit, they have 1/16 wall bronze bushings in them back in 2012. See here. The larger Dexter unit is above
And just the EQ zoomed in to see better
There is obviously a manufacturing goof up somehow/somewhere. If you bought the smaller EQ, they may have only put in thinner bushings and not allowing the Never Fail bushing upgrade. Did you ask if Never Fail could be used with the EQ unit you bought?
I will also add as an FYI, on mine, the larger unit, I ended up putting wet bolts with a grease fitting on the bottom center 2 pivot points of the lower arms in the EQ unit. They have been reported by others to freeze up and no longer pivot. Mine did not yet bind up but where close. Now that I can lube the pivot points, all is well.
Hope this helps
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
