JBarca
Mar 30, 2017Nomad II
DesertTracker wrote:
I did go with the smaller (4-6K per axle) equalizer, mostly since my trailer has a max weight of 6K. There are no brass bushings installed from the factory in either set of equalizers I received, just the thin .040" plastic ones that easily push in and out with my fingers and are loose around the 9/16" step bolts. The brass bushings that Lippert sent after I questioned them do not fit no matter how much pushing with a C-clamp; I think any more force will distort the bushing. I will look into the larger equalizer; sounds like I should have the first time.
OK, I now better understand your axle sizing. My bad for not understanding your camper sizing better. If the entire camper is rated at 6,000# GVWR, then the larger EQ unit most likely will be be way too big. You will have a large shackle length issue.
My comments where where based on the overlap of size ratings. LCI has a LCI spec sheet on EQ 4,000 to 6,000 rated smaller one and a 5,000 to 8,000# rated larger one. The issue I found is when you are into the cross over area. If you have 5,000# to 5,200# axle sizing, on a approx 10,000# GVWR, you could by the spec's, go with either one. In this case the larger unit is better because of the weight ratings.
In your case, yes, the smaller unit fits better from a sizing stand point. I really think now seeing how small your axles are, the big unit it way too big. Odds are high you may have 3,500# axles tubes with 3,000# springs creating a 3,000# GAWR.
To help you not accidentally buy a way too big EQ, see these dimensions on what the big one is.
Now what can you do? It appears LCI changed something and their documentation is not easy to follow. LCI EQ page Even in this scrolling video, they show the Never-Fail bushing along side the smaller EQ unit. But as you have in your hand, they do not fit.
Some options to investigate.
1. Deal with the Trail Aire nylon bushings. An option, just not a great one. It would be good to know what they do not put the Never Fail as an option to install in these. Or even an upgrade to a reasonable bronze. Only having the nylon if that is what they did, would be a kill shot for me. The nylon just does not hold up long term.
2. What will not work right with the smaller Dexter unit? You can buy different length shackles. Dexter has very good aftermarket support that "helps". Give their 1 -800 tech service a call.
3. Mor-Ryde now makes these rubber equalizers too. You will have to sort out the correct shackle length for these too. I have seen these and helped rebuild one before, they are well made.
Hope this helps you sort out your situation. Let us know how you end up. I had a special axle spacing other then the standard and had to go through all this, just the larger system. Seems you have the same issue just on the smaller system.
John
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
