coachcollins42
Apr 17, 2017Explorer
I need some help. I needed some new springs as mine had flattened out over the last 9 years and I ordered the EX Flex to upgrade the equalizer as well. I have 5200lb Alko Axles with 4 leaf springs. My spring hanger spacing is 29.5". My Alko Equalizer measures 6.25" from center to center and my old springs were 26".
I ordered the smaller EZ Flex and 6K 26" leaf springs from Etrailer. The new springs came with 6 leaves.
OK, here is my problem. When I installed the first side, instead of the EX-Flex looking like a W in looks more like an inverted M. The shackles are vertical almost. I am worried that I may not have room for flex during bumps, etc.
I called Dexter and they are not sure what is the problem. They confirmed that 26" springs are the correct springs for 29.5" hanger spacing. My old side with OEM equipment does not look like a W either though. I do not have a picture though.
Any help is appreciated and thank you in advance.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.257 PostsLatest Activity: Sep 17, 2026
