coachcollins42
Apr 17, 2017Explorer
What is the original center of axle to center of axle? as measured horizontal across
33" exact
Does the spring pack sit on top of the axle tube or below the axle tube?
Overslung axles (axle on the bottom under the springs)
Can you tell us on the new springs, the vertical distance at the top center of the long leaf with the spring eyes, up to the centerline of the 2 spring eyes? I know on the old ones, they are flattened and you can't get a good number, but you have the new ones and I may be able to help some on the old ones. Take the dimension with no load on the springs
4.25" on the online drawing from etrailer but I will double check tonight and make sure).
Great suggestion on the picture from the other side. I will take some more tonight and report back. Thank you in advance!
33" exact
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
