Does A Ford 6 Liter Coolant Filter Work And FICM Test
Does A Ford 6 Liter Coolant Filter Work And FICM Test See what it looks like inside a coolant filter when I take it apart and clean the filter. Does it really work protecting your engine? The truck is still running rough with codes for injectors 1 and 8. I am eliminating possible causes, step by step. The FICM voltage test is the next step and if that checks out ok, then I move along to the fuel system to determine if that is the problem. If you have a FORD 6.0 or 6.4 liter engine, this may help you.
Since the wire harness and FICM seem to check out OK, My next avenue of investigation is with the fuel system. I will change the filters with Motocraft, and test the fuel pressure static and under load. I can also check the pressure regulating spring and replace it with a Blue Spring kit. That kit is supposed to be one of the best and easiest upgrades you can do. As per usual, I'll keep you informed of progress on getting this bugger fixed. Thanks for any input.
