Your truck looks gorgeous I just got a a 2014 f450 king ranch want to do something similar what offset and lift did u do
I am sure the OP would appreciate the response, but this post is 4 years old and the OP hasn't been on here since. As a visitor I am not sure you can see the age of the topics so you probably would not have known. It's technical problem with the site and the moderators haven't done anything to fix it.
- blt2skiSep 01, 2024Moderator
way2roll,
We moderators do not have a way of fixing the issue talked about, ie stopping the ability to pull up a post from x months/years ago! If we are going to blame someone, blame the upper management folks, and or the designer of this platform for allowing it....or upper folks have not turned off that ability.
With this said. I've really only had issues with one brand of 19.5 tires on my Navistar since I bought it in 93 or there about. That was MIchelins XRV in an 8r19.5. hwy tire, soft is warm IC! On the other hand, I have some predecessors to the XDR2 that the OP talks about on the rear. THey've been great tires. 60+K miles, got them in 03, still have a few miles left in them! then again, I don't drive this thing much, so I am not driving 60+ MPH across hot asphalt in the AZ to Texas deserts at 100+F. I would suspect I would have issues with them by now! I've switched to 225-70-19.5 tires. I'm positive my suspension is heavier than the 450 mentioned at 24K total front and rear.Marty
- way2rollSep 02, 2024Trailblazer
I hear ya Marty, but usually the mods are missing on these forums and I feel like they would have conduit to get some of these changes made. I mean, the mods asked for feedback months ago and nothing ever happened. No offense to you, just an easy fix. If a topic is more than 2 years old, lock it.
- blt2skiSep 03, 2024Moderator
Unfortunately, notuch is going on here. To lock these, weods, who's left per say. Need people above to program this into the system. Ie no reviving post over 12 months like it was. My literal only option is to delete the offending post(s). I have not had the beef to delete anything since the new format. I've seen the buttons to do so. It's not as simple as the older format.
I check in every few days now. Take care of the one post that shows up. I'm close to leaving per say.
