deleted-2
Apr 18, 2013Explorer II
Towing with the 2005 RAM D3500 DRW CTD HO and Getrag 6 speed manual with a 4.10.
Very much so!
No a few minor fixes under warranty...I do my own oil changes.
This Dodge has cost virtually nothing to maintain.
Largest expense: 7 tires will run anywhere from $1268.00 to $1889.00 depending.
Former truck was a 1992 F250 Lariat 460 CE towing package with the E4OD trans purchased brand new (Trans replaced 3 times over 118,000 miles).
Had this Ford about 3 years before towing with it.
Bought the Dodge RAM July 7th 2005 in Utah $47,495 on the factory sticker.
2012 Heartland Greystone 32RE GVWR is 13,461 loaded
Diesel (I will probably switch to a GMC with the Allison in the future)
1. Happy with your choice?
Very much so!
2. Are maintenance cost as high as you were lead to believe?
3. What gas rig did you switch from, to which diesel?
4. What are you pulling and what is its GVW?
5. Will your next TV be Gas or Diesel?
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
