Lantley
Sep 26, 2023Nomad
spoon059 wrote:ford truck guy wrote:
what are you looking for? 3/4 ton,1 ton? DRW, SRW ? trim level?
Researching right now, but looking at 1 ton trucks in either XLT or Lariat. The bride will need to decide if XLT has enough gadgets for her or not.
I'm curious how much actual payload is available in the 12,400 GVWR trucks with those trim levels. Otherwise, might be looking at a DRW.
Get the dually and forget about any payload concerns.
While you may have to avoid a drive thru you will never have any regrets while towing, which appears to be the sole reason for buying the truck.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
