blt2ski
Sep 26, 2023Moderator
Depending upon the option pkg, cab style, a SW 25/35 series rig may have more or less the same payload as a dw. My 8600 GVWR GM 2500 reg cab gas with very few options mind you, had 3700 lbs of payload, meanwhile the 11,200 gvwr DW CC D/A rig I had, was 4100 per the door stickers on both. I only had 1200 or so to the axel limits on the 2500, and close to 2000 for the SDW rig. Depending upon the how you want to classify the payload. SOME SW rigs may have as much or more payload, easier driving etc than a DW rig.
Generally speaking, also a gas rig will have 400-600 lbs more payload than a diesel assuming the same specs all around with options, axle capacities etc. Being as the motor is lighter than the diesel. A short bed ie 6' bed will net you 200-300 lbs more payload than a std 8' bed, again, assuming the same options etc on both rigs. Ext vs crew cabs are also about 300-400 lbs difference.
There were three of us at one time, that had 05 DW GM CC rigs. One a lower level rwd, he was 400 lbs less wieght than my LS 4wd, I was 200 lbs lighter than the other with a full leather bucket seat setup.
Amazing what some of the options add wieght wise to screw over the brochure payload numbers.
Marty
Marty
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
