Lantley
Sep 27, 2023Nomad
A 40 ish foot long toy hauler requires a DRW.
We often forget our objective and put too much emphasis on non factors.
If you were need to install big nails you would get a big hammer.
You would not buy a medium hammer or a small hammer.
You would not get a medium hammer because it was easier to reach.
You would not get a medium hammer because it was a little cheaper.
You would get a big hammer to use with the big nails.
Sounds like you want are shopping for the biggest 5th wheels available.
You need to shop for the biggest truck available.
Don't let non factors cloud your judgement.
Will it fit in the garage, can I get into the drive thru, are all non factors when it comes to towing a 40 ish long fifth wheel.
I drive a DRW daily its really no worse than a long bed CC truck.
Length is a bigger factor when it comes to maneuverability and nimbleness vs. width. You're not going to just zip around in a SRW CC long bed truck.
Both SRW or DRW CC long bed trucks require you to park a little farther away and are not great in urban areas.
If you consider the mirrors a SRW is just as wide as a DRW.
Yes I'm trying to say get the dually you won't regret it for a 5'er that big.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.257 PostsLatest Activity: Sep 17, 2026
