Kenneth
May 12, 2005Explorer
From the patent:
--quote--
Fishtail sway is caused by the large distance between the rear axle of the tow vehicle and the hitch assembly and is aggravated by lateral forces against the vehicle caused by winds or passing vehicles. Previous attempts to solve fishtail sway involve stiffening the connection between tow vehicle and trailer by using various methods of friction. While these methods help some, none completely correct the problem.
Fortunately, in U.S. Pat. No. 4,722,542, hereafter referred to as the "Hensley hitch", the sway problem is effectively corrected by forcing the hitch to turn through converging links that effectively move the pivot point between the tow vehicle and trailer to a point near the rear axle of the tow vehicle. Therefore, this design provides better steering and control of the trailer by eliminating trailer sway. While the converging links do this very well, the gross trailer weight is limited by the size and design of the converging links in '542 because so much of the tongue weight is supported by the converging links. As a result, increasingly heavier tongue weights require larger links, larger bearings, larger spindles, and larger related support systems. Increasing the size of these parts also increases both the hitch weight and the cost of manufacturing. In addition, the Hensley hitch needs workable brakes on the trailer controlled from the tow vehicle. Without trailer brakes or even with surge brakes the converging links tend to move to one side or the other due to the trailer pushing on the hitch assembly when the tow vehicle brakes are applied.
--end quote--
The original patent, #4,722,542
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1=4,722,542.WKU.&OS=PN/4,722,542&RS=PN/4,722,542
The new hitch and its 2005 patent, #6,851,696
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=/netahtml/search-bool.html&r=1&f=G&l=50&co1=AND&d=ptxt&s1='hensley+hitch'&OS=
--quote--
--end quote--
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
